Ogg & Mp3
Scott
Ogg & Mp3
Post by Scott » Thu Apr 12, 2007 11:14 am
I usually don't get to listen to show live due to other commitments on Wednesday evenings. Are you guys aware that this morning (Thursday 4/12) the Ogg and Mp3 links from last nights show are bad?
Post by Patrick » Thu Apr 12, 2007 11:16 am
I downloaded both files this morning from the office (around 8:00 AM, EDT) without issue. What time did you try to download them? We use rotating mirrors. There could of been a problem with one of the mirrors. If it fails on the first attempt please try it again. The next mirror will be used.
Scott
Post by Scott » Thu Apr 12, 2007 11:21 am
Right now. If you attempt to download the file is empty (1 KB) or if you follow the link it gives you a 404 error. I am accessing it from the following page:
http://feeds.feedburner.com/TheLinuxLin ... vorbisFeed
Post by Patrick » Thu Apr 12, 2007 11:24 am
Scott wrote:Right now. If you attempt to download the file is empty (1 KB) or if you follow the link it gives you a 404 error. I am accessing it from the following page:
Bad link. I see the problem. Dan has to take care of that. Unfortunately I don't have access to the feeds. You can download the file from the main page. That definitely works. Thanks for the heads up.
Scott
Post by Scott » Thu Apr 12, 2007 11:44 am
Got it from the main page. I usually download it from the feedburner site. Thanks for the quick reply Patrick.
Post by dann » Thu Apr 12, 2007 1:46 pm
Hmm, odd. It worked fine with bashpodder. Anyway, I fixed the error I think but we'll have to wait until feedburner updates it's links.
