Linux as a Server???
dookiesmack
Which distro would you recommend for a standard linux server? (e.g. File, Print, WEB). On a machine with 256mb ram 1ghz cpu? I want to setup a print server so my wife and kids can print to my laserjet but I also wanted to setup up a web server.
Hi,
if You want a really, really easy install - try out
ClarkConnect 3.2 Home edition
http://www.clarkconnect.com/
Or
SME Server 7.x
http://contribs.org/modules/news/
These are all "Server in a Box" distros, really easy to set up, You use a web interface to set up the server, once it has been installed. They are both based on the CentOS distro.
If You want a little more control of the install, You could try out Centos, Debian, Slackware, Suse - Just to name a few. I like CentOS and SUSE - But that's just me ...
Good luck !
Or
SME Server 7.x
Good luck !
IT is No exact science
Re: Linux as a Server???
I say go with CentOS or SUSE, I like SUSE because it's great management tools. You can either choose to install the GUI, configure the system and diable it, or just install a minimal test-based system with the ncurses version of YaST which offers pretty much the same functionality as the GUI.dookiesmack wrote:Which distro would you recommend for a standard linux server? (e.g. File, Print, WEB). On a machine with 256mb ram 1ghz cpu? I want to setup a print server so my wife and kids can print to my laserjet but I also wanted to setup up a web server.
SUSE also comes with a big bunch of drivers for all sorts of good stuff, has a good GUI for setting up Samba, Apache the firewall and all that good stuff.
When I do servers with SUSE I just do a text install and configure it using the ncurses version of YaST, works out pretty well, and when I'm lazy I just install the KDE desktop, configure it, and disable X so that it just dumps me to a Bash login after the system ha booted.
