python code to access hardware.
davijordan
Post by davijordan » Tue Dec 11, 2007 7:02 am
Is there code for python to pull or send bitwise data to either the parallel or joystick ports?
Philus
Post by Philus » Tue Dec 11, 2007 7:58 am
like this?
There's also one for the serial port.
My 5 minute google search didn't find anything useful for the joystick port, except that it should be doable, at least on linux. My python skills are probably not quite up to it though.
riddlebox
Post by riddlebox » Tue Dec 11, 2007 5:46 pm
I briefly did a project using pyparallel it is pretty easy to deal with
davijordan
Post by davijordan » Wed Dec 12, 2007 8:24 am
I saw that on the net also. i will check it out. I am glad to know it works.
allix
Post by allix » Wed Dec 12, 2007 9:45 am
you mention joystick are you writing a game? I am sure pygame has something so you can work with joysticks and stuff
http://www.pygame.org
davijordan
Re: python code to access hardware.
Post by davijordan » Thu Dec 13, 2007 6:30 pm
Thanks for the link. At this point, all we are trying to do is to be able to use all ports possible for not only access to digital and analog data but to be able to control the ports via a scripting language. I have the last batch of parts on order for our project. Once I get those, it will be time to start building interfaces and testing.
