Power Button Stuck on M-350 Case
sk8er3810
Post by sk8er3810 » Wed Mar 10, 2010 2:51 pm
I love the M-350 case and it seems to be a popular choice in this forum. Has anyone experienced the plastic power button getting stuck/jammed in the depressed position? The only way I can get it unstuck is to take off the top cover and then remove the front panel.
Re: Power Button Stuck on M-350 Case
Post by Patrick » Wed Mar 10, 2010 3:00 pm
The issue is you have to put on just right when you snap it on. It it's not on there correctly it will jam up on you.
